New Fed P25 System - Bay Area / Central Valley?
ECPD279
Bay Area, CA
While searching the bands today I came upon what I believe to be a new P25 system in the federal UHF band. Here's what I have so far from DSD+FL...
System: BEE00.98D
Site: 1.2
NAC: 980
2-856 385.35000
2-976 386.10000
2-992 386.20000
2-1080 386.75000
ID=1 Base=762.00625 Offset=+30 Spacing=6.25 BW=12.5
ID=2 Base=380. Offset=+10 Spacing=6.25 BW=12.5
ID=3 Base=406. Offset=+9 Spacing=6.25 BW=12.5
ID=4 Base=136. Offset=+8.375 Spacing=12.5 BW=12.5
ID=5 Base=380. Offset=+10 Spacing=6.25 BW=12.5 Slots=2
ID=6 Base=406. Offset=+9 Spacing=6.25 BW=12.5 Slots=2
ID=7 Base=136. Offset=+8.375 Spacing=6.25 BW=12.5 Slots=2
No neighbors detected.
This site is Mt. Diablo strong from Martinez. The only 98D I see in the DB is in Kentucky, so this is either new or the skip today is phenomenal ;).
ecps92
Taxachusetts
First blush , any Army Bases near-by
maybe the Army is going the way DoD/Navy and Air Force have gone with wide Area Trunks and KY needs to be Re-labeled?
System: BEE00.98D
Site: 1.2
NAC: 980
2-856 385.35000
2-976 386.10000
2-992 386.20000
2-1080 386.75000
ECPD279
Bay Area, CA
Not anymore. Last one was Oakland Army Base in the 90's. Nearest thing would be Camp Parks RFTA in Dublin, but they already have a system. I can't hear them from here though, so unknown if this is perhaps a replacement system.
Outerdog
T¹ ÆS Ø
Got it here in Martinez as well. Signal is stronger than what I typically see for EBRCS. You missed Channel ID 0.
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
I'm receiving the signal on an external antenna in South Sacramento. Today, the control channel is 386.10, with the other three frequencies listed as secondary control channels (385.35, 386.20, 386.75).
mcjones2013
Sacramento, CA
I parked DSDPlus on this system overnight, and was able to catch some activity. Radios are in the 81xxxxx range. All traffic is encrypted.
Groups:
P25, BEE00.98D, 53001, 50, Normal, 5, 2023/02/02 9:10, ""
P25, BEE00.98D, 53016, 50, Normal, 165, 2023/02/02 9:33, ""
P25, BEE00.98D, 53059, 50, Normal, 0, 2023/02/02 5:48, ""
P25, BEE00.98D, 53060, 50, Normal, 1, 2023/02/02 8:50, ""
P25, BEE00.98D, 53061, 50, Normal, 0, 2023/02/02 9:32, ""
P25, BEE00.98D, 53062, 50, Normal, 17, 2023/02/02 9:31, ""
FD101
That’s correct, We have a 98D system here in Richmond, KY. The system serves as the primary communications network for the Blue Grass Army Depot, one of only two facilities left in the Chemical Stockpile Emergency Preparedness Program (CSEPP).
I’ve noticed that the Fort Knox system shares the same WACN ID with Fort Benning as well as Fort Bliss. It seems to be a common WACN ID used by the U.S. Army.
Interesting timing though on your post… the Blue Grass Army Depot switched their SYS ID, WACN, NAC, etc just a few months before your post.
I’d agree with @ecps92 that the Army has gone wide area and that the DB should be updated to reflect and consolidate all the shared systems.
FD101
That WACN (BEE00) is the default for most if not all Motorola-built systems.
I'm curious what the use is around here for this system.
I was referring to the Ft Knox WACN, not the default BEE00 WACN that’s being used on this system.
