New Firmware release information
Arizona
Kenwood released new firmware for a few radios for Valentines Day
NX-5000 series V5.01 Checksum 4C7D
NX-5200S series V5.01 Checksum 4C76
NX-1200N series Type D trunking firmware Checksum 67FE
NX-1200D series DMR firmware Checksum 70CF
NX-1200N NXDN firmware Checksum 583B
NX-3000 series V4.00 Checksum F45B
NX-1700 radios Checksum 0A93
kd4efm
EL98 Florida
New firmware released for the NX-5000 S MODELS
Version 5.01
NX-5200S, NX-5300S, NX-5700S, NX-5800S
NXR-710, NXR-810 FIRMWARE RELEASE
VER 4.09
contact your dealer for more information
03msc
RF is RF
The Natural State
Version 5.01
VER 4.09
These are the only new ones, correct? His post above yours confused me because 5.01 for the regular 5000 series came out months ago.
kd4efm
EL98 Florida
Firmware update notice;
NXR-5x000 series repeaters NXR-5700K_V541_8021
NXR-x00 Series repeaters NXR700KE_V541_1717
No new notes on the minor update.
  • Improved Stability.
  • Added New Models.
  • KAS-20 Compatible.
  • Resolves an issue where CCH stops transmitting.
  • Resolves an issue where the repeater doesn't completely reboot after writing data.
  • See Technical Information Bulletin TIB-0102.
  • Works with KPG-D2N Ver 5.00 or later.
  • NXDN Type-C Trunking Support.
  • Added NXIP Site ID function on Conventional.
kd4efm
EL98 Florida
just a quick update on fw releases
NX-5000 5.01
nx-5000s 5.01 (the nx-3000 clone)
NX-3000 4.01
NX-1000 PORTABLES 2.14 (Analog, dmr, nxdn)
NX-1700-1800 mobiles 1.13
Legacy Radios
NX-x00 & NX-x20, 5.36
NX-x40 V2 Portables 3.11
NX-x40 V2 Mobiles 3.09
repeaters
NXR-1700 1.05
NXR-5x00 5.41
NXR-x00 5.41
NXR-x10 4.09
TKR-Dx10 3.05
Gen 2 Trunking 1.89
kd4efm
EL98 Florida
Viking update.
  • FSN-0923-VIKING-29_23.1.2_Viking_Subscriber_Software_Maintenance_Release2023-10-02 (2).pdf
tweiss3
Is it time for Coffee?
Ohio
minor updates out
5.12 NX-5000
S_5.12 - nx5000s; S series
4.12 NX-3000
I know they don't have release notes, but any idea if this fixes the mute on startup issue?
DarcyB
5.12 addresses issues around:
  • TX led issues when DMR site roaming
  • Motorola P25 Phase2 voice interop
  • DMR busy channel lockout
  • compatibility issues when receiving SDM
wd8chl
Btw, anyone else notice that new NX1200/1300 are showing up with fw 2.15, but the newest on the web site is 2.14? :unsure:
RRR
OFFLINE
USA
For the love of God, can we please get an option where the display turns on when there is carrier / conversation detected? Green light on, display lit.
bjred
From what I've been told, the 2.15 firmware is a special version that is to be used only on specific NX-1300s. Applying this firmware to radios not on the list can cause operational problems with the radio.
AM909
Radio/computer geek
SoCal
Product Bulletin P23-A-09LM, issued Aug 15, 2023, discusses Service Bulletin LSB-0377, which discusses the update. Service Bulletin LSB-0378 describes the change that caused the issue.
On the face of the box with the serial number label, the ones with updated (D2.15) firmware have a "6" stamped at the upper-right corner. Recent ones that do not need the update have a "5" stamp instead. If there is no stamp, it probably has x2.14.00 and you should consult the list of serial numbers to see if it needs x2.15.00. Apparently, you have to contact support to get it; they want to make sure it doesn't get used on older hardware.
wd8chl
Just sayin'-every radio we've gotten over the last couple of months has had 2.15 in it. And that's at least a hundred radios.
