New Fleettalk site in Edgefield County
shajoe44
North Augusta, SC
There is a new site in Edgefield County. I have submitted the information.
WRPH911Rock Communications452.61250FB6/MO602/07/2022NewNXDN
WRPH911Rock Communications457.61250FB6/MO02/07/2022NewNXDN
WRPH911Rock Communications461.61250FB802/07/2022NewNXDN
WRPH911Rock Communications461.88750FB6/MO02/07/2022NewNXDN
WRPH911Rock Communications461.96250FB802/07/2022NewNXDN
WRPH911Rock Communications463.26250FB6/MO02/07/2022NewNXDN
WRPH911Rock Communications463.78750FB6/MO02/07/2022NewNXDN
WRPH911Rock Communications464.33750FB6/MO02/07/2022NewNXDN
AB4BF
EM93cs
Evan, I don't know if it has ever been mentioned, but the Johnston tower off of SCHWY 23 north of Johnston (our Verizon/PAL800 tower) has NXDN digital frequencies on it and has for several years. I have never seen it on the list. Clandestine, perhaps?? lol
EmitterClassFreq(Num)Freq(MHz)Power (Output Watts)Power (Radiated Watts)
1FB81463.6625100125
1FB82464.8125100125
1FB83464.9625100125
2FB61451.45100125
2FB62452.25100125
AB4BF
EM93cs
463.6625 is site 32 of TRBOMAX system
464.8125 is a CAP+ DCC:5 unknown system.
Hi shajoe44, is TRBOMAX the same as NXDN? I apologize, I'm terrible with the digital systems. Also, what's CAP+ ?
brian
DB Administrator
South Carolina
TRBOMAX is the name of a specific trunked radio system in South Carolina. It happens to be owned and operated by Motorola, which is a manufacturer of DMR (and other digital modes like P25) radio hardware. So not only does Motorola sell hardware to agencies/businesses for "private" radio systems, they also deploy and operate their own radio systems for profit.
Many other manufacturers, besides Motorola, make DMR radios and even radios for DMR trunked radio systems.
TRBOMAX happens to be based on one flavor of DMR trunked radio systems called Capacity Max system, which is the Motorola brand name for (generically) DMR TIII. Motorola adds some proprietary features to the generic TIII standard that make their systems unique.
Capacity Plus (or Cap+) is another flavor of DMR trunked radio system from Motorola. It's a unique Motorola-specific trunked system. Yet another flavor of DMR trunked system is ConnectPlus, which is similar to TIII, but again, Motorola adds some features to make it proprietary to Motorola.
Fleettalk is the name of a trunked radio system, but it's the name of a common "platform" across many states. Technically all of the Fleettalk systems are separate systems that share the Fleettalk brand name, but multiple vendors/radio service providers contribute frequencies and hardware (tower sites) and also sell airtime on the system. It uses the digital radio type called NXDN, which is similar in some ways, but incompatible with, DMR. NXDN equipment is made by Kenwood (NEXEDGE) and Icom (IDAS), among others.
It's easy to get protocols/specifications (DMR, NXDN, TIII, etc) confused with trunked radio system flavors (Cap+, CapMax, etc) with service providers/vendors (TRBOMAX, Fleettalk, etc).
AB4BF
EM93cs
I'm guessing the different digital systems will sound like different brands of motorboat outboard motors on the scanner? P-25 = Evinrude, DMR = Mercury, etc. LOL! JK...
Now, seriously, the different digital systems out there, which ones will the DMR Uniden Bearcat licenses will open up which digital system signals? I purchased the DMR and NXDN licenses and installed them on my 996P2. I have yet to receive any digital transmissions on my scanner - even amateur radio using the aforementioned licenses.
(P25 doesn't count, I get it regardless) I've followed the WIKI instructions to the "T" and still nothing. I guess I'm not holding my tongue correctly and wiggling my ears when I press "enter" on the computer... using Arc XT Pro.
brian
DB Administrator
South Carolina
P25, DMR and NXDN are the general names that correspond to the most common digital voice protocols that you'll typically here in the usual scanner bands. There are plenty of others - Tetra, iDen, Opensky are a few examples - that have more specialized applications. And yes, to the trained ear, they all sound different.
P25 is by far the most common digital protocol used by public safety agencies, mostly because it's endorsed by government for interoperability purposes. Therefore, grant funding to agencies often applies exclusively to P25 equipment. P25 audio can be used on conventional radio systems as well as trunked radio systems, and the same P25 voice protocol is used for both Phase I and Phase II systems.
DMR probably has a higher market share for business use because it's the protocol endorsed by Motorola. It can be used on conventional systems (simplex and repeaters), linked repeaters, or with various flavors of trunked systems. Those include Capacity Plus, Connect Plus, Capacity Max (all Motorola brands) and TIII (a common standard).
NXDN is the other leading digital standard for radio in the US. And again, it can be used on conventional systems or trunked systems. NEXEDGE is the trunking flavor sold by Kenwood, and it has two flavors (4800 and 9600). Icom IDAS is another brand of the NXDN standard.
In South Carolina, there are several P25 trunked systems around, with Palmetto 800 being the biggest and statewide accessible. The SC PSA is another one that's almost statewide, and you'll see some Phase II activity on it.
There are DMR radio systems (conventional and trunked) all over the state, and it's probably difficult to find an area that you can't hear DMR signals. TRBOMAX, the Charleston Wireless linked system, Capital City TBRO, the SCANA system, the SC HEART amateur radio system and dozens of smaller private systems are all based on the DMR voice standard.
NXDN isn't as common in SC, but the Fleettalk system has sites pretty much all over the state.
The Uniden DMR and NXDN licenses enable the scanner to decode voice/audio of those particular protocols. That means that if you tune to a frequency using either of those voice protocols, regardless of trunked flavor being used (if any), you should be able to hear the audio with a scanner that has those licenses applied. However, trunk-tracking a trunked system that uses these voice protocols is a different matter. Some scanners may track most or all of these different flavors of trunking, others may not. And for many of these systems, the RadioReference database is incomplete. This is particularly true with respect to channel numbers, which is a requirement for Unidens to properly track some of these system types. This MIGHT be where you're running into trouble with your 996. That's why it's important to have folks with the skill and software that can decode and gather this information and submit it to the database. But it's painstaking task. Whistler scanners, which don't technically trunk-track DMR and NXDN-based trunked systems, have an advantage in that they don't require channel numbers to "scan" these systems. And you don't have to pay for additional licensing.
The RadioReference Wiki has quite a bit of documentation about digital radios standards that will provide much more detail that I can post in the forum.
Just to get you started:
AB4BF
EM93cs
Thank you so much, Brian, I will give it all another spin. I'll let y'all know what I was doing wrong if I get it to work...
