Just got a new home patrol scanner in today, anyone have one and did anyone note that the NJSP Trunked system not supported ? If so what service group are they under law enforcement ?
They're geo-tagged now for the three main sites. When I can get to the IR sites this weekend, I will...
Edit - they're all done now - it takes a little to get used to using the geo-tag feature, but it's pretty easy once you get the hang of it!
I don't know if these need to be done, look in the database, in the NJ State Police Reports section, Other Reports (TG Location Report & Site Location report) I guessing here, maybe one of the other Admin can answer that.
Only two of the IR sites actually had geotags on them - I did the rest this evening. I put the tags in for those that might use them - I don't live anywhere near any of them & will 'avoid' them on mine when I do get it...
You're seeing those location specs in that report because I just did them...
I was mainly talking about the TG one.
I flew through a bunch of long-standing NJ trunk systems - NONE of them have location data for the talkgroup categories...
Thanks for the update, should I have Law Enforcement highlighed in the ( Select Sservice Types ) ?
Are you able to program the HP-1 yourself or only from RR? There are many frequencies in my scanner that are not in the RR database.
W2SJW, not to hijack the thread but do I need to reprogram my scanner for the updates to the NJSP system you did?
How you making out Tony, are you montoring the system yet?
Highpockets said:W2SJW, not to hijack the thread but do I need to reprogram my scanner for the updates to the NJSP system you did?
If you have a Uniden scanner and use a GPS with it Yes. If you have a GRE or Radio Shack scanner No.
Steve...
I was not able to do an upload yesterday it software said that the server was down or something like that..
On a side note, the radio is picking up the Morris Co TRS system here in Harrison now which I am very happy about none of my other radios where able to do it like the 996XT.
I bought the radio mainly when I travel no more having to sit there and program my radio for hours.
If anyone can check this out please see if Belleville Fire is in the data base because I was sitting on Essex County this morning while Belleville was doing there test and did not pick them up at all.
154.220 PL 141.3
Tony
