new iowa dot freqs and codes
stummej
Iowa City, IA
Finally got home for winter break and first good snow up here. I've been scanning for dot codes and have come across some new ones. This is what I have so far
Algona NAC:014 on 156.0450
Garner NAC:021 on 159.1950
????? NAC:027 on 159.1950 (had to much error to listen so i would say somewhere around belmond or nora springs)
timkilbride
Iowa County, Iowa
It would be be nice to get the whole state done with frequency and NAC code. I hate to generalize my tags in the my scanner "DOT Repeater". I rather have a name(town/county) and NAC to go along with it and throw some GPS coornidates on it, rather then use quick keys. The only thing I have to decode NAC is on my scanner in the car.
Tim K.
IowaBrian
Michigan
They are using the ISP HELPER here in the CR area for plows, along with what is in the data base already.
stummej
Iowa City, IA
Got a new one today :)
Mason City NAC:022 on 156.0450
and as i was headed to i35 i picked up the nac 027 one again.... I could actually hear what they were saying for the most part but somehow people forget to say city then unit id or even clear....
timkilbride
Iowa County, Iowa
I did some looking at 159.150. Hampton, Charles City, and Hanlotown are licensed for 159.195(100 watts).
I'm not saying this is one of them, but could maybe help you pin point???
Tim
stummej
Iowa City, IA
def not hampton, most likely not charles city because when i received it i was at 9 and I35, where i just started to pick up mason. im guessing hanlontown but if its 100w then it shouldnt have been choppy...
well i have one more week to figure it out, im going to be headed back to cedar falls on thursday.
timkilbride
Iowa County, Iowa
fireside
Tama IA.
You the man stummej. I submitted what i could hear here. It would be nice to get most of the state with NAC codes.
stummej
Iowa City, IA
Latimer 159.1650 NAC 27
Hampton 159.1200 NAC 24
Floyd 151.3250 NAC 23 TRAFFIC ONLY!
CC 159.1800 NAC 17 TRAFFIC ONLY!
Nashua 158.8950 NAC27 TRAFFIC ONLY!
Plainfield 159.1200 NAC 24 TRAFFIC ONLY!
South Plainfield 158. NAC29 TRAFFIC ONLY!
Marshaltown 800 NAC 4
Williams 3253 NAC 3
west of williams 156.0540 NAC 2 TRAFFIC ONLY!
Ames 151.0850 NAC 7
??? 154.0420 NAC 2 TRAFFIC ONLY!
The ones with traffic only are where i was when i heard it. I didn't get a name because of high error rate or people not following protocol on the radios :D
edit: PS just thank new years in des moines for all of this :)
W0GEN
Waterloo, IA
Are you saying that Marshaltown Freq is 159.800 or 158.800?
I have been getting some NAC activity from my GRE-500 and will need to start writing them down for the Waterloo area.
timkilbride
Iowa County, Iowa
Are there other IDOT frequencies that are active in the Council Bluffs area besides 159.195?
Try this Rich:
151.085
151.190
151.250
151.325
156.045
158.895
159.120
159.165
159.180
159.195
159.360
Those are used statewide in Iowa. Some frequencies double as a input in one area and as a output in another area. For the most part, each county in Iowa has a DOT shed. I would guess you can probably hear 2-4 different sheds.
Tim K.
timkilbride
Iowa County, Iowa
Here is what I could dig out of the FCC search:
Pott County:
Avoca, Oakland, McClelland, Council Bluffs, Miden Township: 159.180
Avoca, Council Bluffs: 159.195
Harrison County:
Jefferson Township(Logan): 158.895
Mills County:
Center Township(East of Glenwood a few miles): 151.085, 159.195
That should help you narrow things down.
Tim K.
fireside
Tama IA.
M-town DOT
Iowaponds
Marshalltown DOT is 159.165 NAC 008,i can hear them here. Thats the only freq. i've heard them on.
splash1
Eastern Iowa
At this time hearing Anamosa area dot on 151.190 with nac of 096 ,also hearing 158.895 with nac of 100.
Rick
confirmed 158.895 with nac of 100 to be Tipton area.
W0GEN
Waterloo, IA
Waterloo DOT
I am very active in Waterloo at 159.165 NAC of 032
If anyone has a GRE PSR-500 using ARC Software, I would like to begin a discussion with you. I am trying to understand what the best way would be to program some of these known NAC's. Do we just do a search setting, or can we plug the actual NAC, and if so, where?
stummej
Iowa City, IA
with my uniden 396xt i have a bank of dot freqs set for search and then another with the town/nac combination. I also use proscan which supports recording and history with nac codes if the search is on.
