New Jersey, Ocean County..
gopeder99
Well i was going to posted in the Regional Nj, Forum but it seemed dead...
So My question is the only Frequencies for my area ( brick, New Jersey, Ocean COunty)
Listed on this site?
im looking for high traffic Frequncies, i have a Uniden Bc80xlt, and i have all the frequencies on this site entered in, but theres barley ever talking, like noticably less then there should be, i hear stuff like once every 5 minutes . if that...
also what is "Law Enforcement Interoperability"
Bentley
Freehold, NJ (Monmouth County)
Brick is usually a busy town. Are you looking for Brick Police? Do you have it programmed correctly? 453.050, should be brick PD's main dispatch channel. There are plenty of surrounding areas that you can monitor also, here is a link to the ocean county database section of this site...
http://www.radioreference.com/apps/db/?ctid=1785
Just remember that point pleasant beach, lakewood, and toms river are digital, so unless you have a digital scanner you will NOT be able to monitor them. Even if you do have a digital scanner you will still not be able to monitor toms river as they are currently running full encryption. Lakewood is in the clear.
loumaag
Silent Key - Aug 2014
Katy, TX
Moved to the NJ forum. It is only dead because people keep posting in the wrong place.
gopeder99
i have all the following frequencies in it now.. can you tell me why for instance some are showing 2 frequncies like the first fire m channel has 453 and then 458?
453.25000 458.25000 KUQ731 RM 127.3 PL 1 Fire FM
453.37500 458.37500 WPVZ352 RM 127.3 PL 2 Fire FM
460.53750 WPAM421 M 127.3 PL 3 Fire FM
460.51250 WPAM421 M 127.3 PL 4 Fire FM
465.51250 WPAM421 M 127.3 PL 5 Fire FM
460.52500 465.52500 WNRM841 RM 127.3 PL EMS FM
461.77500 74.4 PL EMS (Alert Ambulance) FM
453.05000 458.05000 KUQ731 RM 127.3 PL 1 Police FM
453.75000 KUQ731 M 127.3 PL 3 Police FM
453.15000 458.15000 KUQ731 RM 131.8 PL 4 Police FM
453.18750 M 5 Police FM
453.82500 458.82500 WYC831 RM 127.3 PL Public Works (Police Ch. 9) FM
155.29500 KTV914 BM 162.2 PL Board of Education - Buses FM
158.77500 KUL795 BM MUA FM
453.86250
DJ88
Brick Twp., New Jersey
The reason "some are showing 2 frequencies", example 453.05000 and 458.0000 is because those are repeater channels. Repeater systems use 2 frequencies, an input frequency and an output frequency. Simplex systems only use 1 frequency. Here's a link that explains this:
http://www.police-scanner.info/scanning/conventional-radio-systems.htm
Scroll up and see "Conventional Simplex Radio Systems" and "Conventional Duplex Radio Systems".
BTW, when programming your scanner, you only need to program the output frequency, which is listed in the first column on the database, to hear everything. Example: 453.050 - 458.050 - only program 453.050. You need not program the INPUT frequency.
Hope this helps you.
fineshot1
NJ USA (Republic of NJ)
Delete the 458.XXXX and 465.XXXX freqs you have programed into any memories as they are repeater inputs and are not needed in these cases. Also - the scanner you have is not a higher end model. When Brick eventually goes digital(probably sooner than later) you will need a digital scanner but if they encrypt their transmissions (as a lot of local agencies are starting to) then you will be SOL like the rest of us as there is nothing that will receive them.
There are no absolutes in scanning so like a lot of other things its a crap shoot.
Good luck....
