New LACOFD Regional Dispatch Centers. Antenna install FS118
CA
#1
3 new LACOFD Regional Dispatch Centers are now in place around the county at existing FS. This is the antenna install at LACO FS118 in Industry. They've dedicated a room for dispatch where utility, PD, FD just about anyone can come sit down and plug in. There's telco D marks and other assets ready to go now in that room. Roof looks like a porkypine now with all the discones, omni bats, data pucks and Sat antennas.. That's the line crew from Pacoima with the clean install.
#3
I presume these are backup dispatch centers and that they aren't returning to the old "Antelope," "Valley" and "L.A." centers for all dispatching.
Palm Springs Area / OrCo
#4
You mean telco demarcation points... The demarc. Is on the side of the premise. I would hope it would be a place to plug in networks and voip( voice over ip) phones. A cell boost would be a plus if the signals are low for all four major carriers. Thanks for sharing btw.. Is there aback uo generator ? Propane ? Natural gas?
bryan_herbert
Las Vegas, NV. DM26jc
#7
I wonder why they chose to install so many discones instead of just one and running the coax to a multiplexer. With the antennas so close to each other you risk not only reception issues but equipment damage as well.
#9
Are these just back up ops centers ? Dispatch is still on Eastern ave. correct ?
CA
#10
They are backup dispatch centers, Eastern still the primary dispatch. I had a list of the other 2 stations that were upgraded, let me see if I can find it. One was AV and the other in LA area.
I'll ask the engineer on why all the discones, I know a multiplexer was discussed on the job walk.
Yeah, mounting all them antennas and drilling holes for the hoses in The Palace was a long job walk lol. They wanted to put them on top the clay roof and ended up on the beams on the backside.
CA
#11
Demarc, demark, samie same. Most of FDs demarcs are inhouse in the comm room, not on the outside of bldg.
I believe they have a diesel generator at FS118. I was shocked to hear from the gen peeps that when they test the gens monthly only about half of them fire up like they should. Seemed like a high failure rate to me.
