New Owner Problems
AC0RV
Park Hills, MO
#1
Ok just received my new 536 HP. I am having my problems with entering the keys for both the DMR and Provice.
Ok (1) the sn on the provice does not much the ESN. I mistakely left the last two digitals of SN off. The serial # should read as follows
37526068001379 with a check sum of 135.
(2) I can not enter the keys the both PROVICE and the DMR.
Other than the radio seems to be working right.
Please send Help and Big Thanks.
fxdscon
#2
Input the key using the scroll knob to select a digit or dash (not the keypad) just as you would enter a text tag. Be sure to input the numbers and the dashes exactly as given.
Use the <4 and 6> key to move left or right to the digit position when inputting the key, do not press "E" until the entire key is entered.
UPMan
Uniden Representative
Arlington, TX
#3
The key you got matches to the ESN that you entered (I checked it). The SN is not used to generate the key.
Make sure you enter the hyphens.
