New privileges for U.S. hams on 60 meters
AK9R
Staff member
Super Moderator
Central Indiana
On December 9, 2025, the FCC released Report and Order 25-60 which amends Parts 2 and 97 to implement acts of the World Radiocommunication Conference held in Geneva in 2015 (WRC-15). The R&O addresses the amateur radio service in the 5351.5-5366.5 kHz (60m) band and the 420-450 MHz (70cm) band. https://docs.fcc.gov/public/attachments/FCC-25-60A1.pdf
In the 60m band, the R&O states "Allocate the 5351.5-5366.5 kHz (60-meter) band to the amateur service on a secondary basis; continue to make available on a secondary basis the four existing channels outside of the 5351.5- 5366.5 kHz band; and establish other operating guidelines for amateur use of the band." The existing 60m channels and their power limit of 100 watts ERP remains. In the new 5351.5-5366.5 kHz segment, power will be limited to 9.15 watts ERP.
In the 70cm band, the R&O states "Update the coordination and contact information in US270 for amateur stations operating in previously defined areas of the 420-450 MHz (70 centimeter) band." This is referring to parts of the country where amateur radio operations on the 70cm band are restricted due to adjacent military operations.
These changes will go into effect 30 days after publication in the Federal Register.
GlobalNorth
Fort Misery
I've never been on 60 meters. My luck is I could monitor a freq for an hour, hear nothing, and and as soon as I hit the TX button - the FCC would get a complaint about my station interfering with a primary user.
K9KLC
Southwest, IL
I've only made rare appearances there. My antenna usually won't tune there but I was setting something up for someone and actually got my wire to tune. I don't remember which frequency it was but there was 5-6 guys on there and I was welcomed to the conversation like I was a long lost buddy.
We had some afternoon propagation similar to what 80 does at night. When I string a new wire next spring I'm gonna try to get something up for that band I think.
Naw get in there and key up, you might be surprised.
Marcy57
Long Island...NY
Kind of a dumb question? since I,m not interested in it anyway but just curious I looked at the 60 meter
thing what license classes is it for (maybe I missed it?) like can a General (like me) use it? is for Extra?
can a Tech use it? 73,s Marcy
K6GBW
Montebello, CA
9 watts with a low dipole and you'll talk for 200-300 miles around you pretty easy. 60m is the playground of the ARES/RACES crowd. At least around here. When I was in the Army we used to use the high 4 MHz and low 5 MHz frequencies with 20 watts or less and it worked pretty well. At least in the mid 80's it did.
