New Release - DSDPlus v2.169
thewraith2008
New Release:
DSD+ 2.169
More DMR TIII messages decoded
FMP24 2.49
Some stability improvements
FMPA 2.27
FMPP 1.0
DSD+ compatible SDR software for SDRPlay RSP2 receivers.
Other SDRPlay receivers are not supported, but some functionality may be possible.
Operation is similar to FMPA; refer to FMP.txt, FMPA.txt and
FMPA feature updates documented in this change log.
Use Notepad to add your SDRPlay serial number(s) to the FMPP.cfg file.
FMPP help summary:
Usage:
FMPP [options] Normal operation
FMPP -h Show help
Options:
-i<num> SDRPlay device number (1-255) [-i1]
-o<num> Output audio device (1-255) [-o1]
-o<port> Output audio TCP port (256-65535)
-A<num> RSP2 antenna select (1-2) [-A1]
-N<num> Enable/disable RSP2 notch filters (0-1) [-N0]
-L<num> LNA gain (0-8) [-L8]
-M<num> IF gain (0-59) [-M30]
-T<num> Enable/disable RSP2 bias tee (0-1) [-T0]
-f<MHz> Initial tuned frequency [-f99.9]
-b<kHz> Initial filter bandwidth (4, 7.6, 9.5, 12.5, 22) [-b7]
-u<num> Enable/disable unlicensed spectrum display (0-1) [-u0]
-z<num> Show zoomed spectrum (0-1) [-z1]
-n<num> Select noise filter (0-2) [-n0]
-v<num> Set volume level (0-500) [-v100]
-s<num> Enable/disable scanner mode (0-1) [-s0]
-wsl<v>.<h> Spectrum window location [-wsl50.50]
-_<num> Minimize windows at startup; bitmapped
-rc Role is trunk control/rest channel monitor
-rv Role is trunk voice channel monitor
Active keys:
0-9 . Enter set frequency
[/] select step size
Cursor </> step frequency
Ctrl Csr </> step frequency by 250 Hz
U toggle unlicensed spectrum display mode
M toggle spectrum memory overlay
X reset spectrum memory
Z toggle spectrum zoom overlay
I select injection mode
b/B select bandpass filter
F select noise filter
Cursor ^/v adjust volume level
spacebar toggle muting
A toggle RSP2 antenna select
O toggle RSP2 notch filters
j/J adjust LNA gain
k/K adjust IF gain
R toggle raw I/Q and FM demod recording
S start scanner mode or exit hold mode
C start trunk control/rest channel following mode
V start trunk voice channel following mode
? list active keys
Esc exit scanner/CC/VC modes or exit program
Left click on spectrum: retune
ATCTech
My DSD+ CC Event Log window is empty, not even the version number and my name/email address on start-up. The corresponding VC Event Log window is populated as expected and the software is decoding normally as usual. The CC Log footer bar is displaying the system ID, NAC etc. including the site name from my sites file. Replacing just the DSDPlus.exe file back to 2.165 fixes the CC Log activity window. I haven't changed the .bat files or command line switches in any way and so far in the text files I don't see any command line value changes I need to make between versions. Anyone else concur?
BM82557
Berkeley Co WV
My DSD+ CC Log window is empty, not even the version number and my name/email address on start-up and the cc.log file is 0 bytes. The corresponding VC log window is normal and the software is decoding normally as usual. Replacing just the DSDPlus.exe file back to 2.165 fixes it. I haven't changed the .bat files or command line switches in any way and so far in the text files I don't see any command line value changes I need to make between versions. Anyone else concur?
I didn't have that, I just unzipped with 7Zip and copied all the extracted files over replacing the originals in my DSDPlus folder.
ATCTech
That did it, thank you sir! It seemed like the foreground and background color values might be the same in .169, but only for that window.
albert1987
Hi,
I've the same problem with DSDPlus v.2.169
Cheers
