BCD536HP: New Sd Card
blackcloud08
NC
#1
Hi guys, I'm trying to make 2 back up cards for my 536 and everytime I try to get the new cards ready it shows the following:
F: Uniden Unknown ( ESN: XXXXXXXXXXX)
I've tried clearing the user data on the new cards and then writing to them from the profile I saved last night from the working card in the 536.
I never had this problem with my 436.
Any suggestions?
blackcloud08
NC
#4
After I clear the user data and it writes to the scanner I can pull up the card on my computer and it show Uniden x36hp with all the files listed firmware, alert, discovery etc... The esn when I look at it on sentinel shows ESN: ( XXXXXXXXXXXX)
I'm going crazy trying to figure out what I'm doing wrong.
I've formatted it with fat32 and named it
Erased User Data
Updated Firmware
Wrote to Scanner
and i'm getting the same ill effects every time.
escortz28
Powell, Ohio
#5
You're ok. The ESN will be written by the scanner to the memory card once you've actually inserted the memory card in the scanner and cycled power.
blackcloud08
NC
#6
That's what I thought but it keeps saying " SD Card Access Error" but i'll do it all again just to say I did.
So the 536 accepted one card but not the other, same process was done on both cards.
srpawski
#7
I didn't have any issues last week when I put in a 32 gig card in my 436. I did have the same xxxxxx reading for ESN, however, I let Sentinel format it and I was able to load the full database to it along with my favorites list. Once I disconnected it from the software after the write to it, and reconnected it, the ESN showed the scanner's number and not xxxxxx.
blackcloud08
NC
#8
Mine only showed up after I put it into the scanner. Idk what the deal is. It took multiple attempts of doing the same thing for it to finally accept it so idk... Just one of those things I guess.
