New SLERS P25 aircraft system possibly found.
james32746
Lake Mary, FL
Last Friday, I stumbled upon a new P25 control channel which sounded like the Harris variant on W2SJW Radio Sounds website. I read some time ago that they were going to convert the SLERS aircraft only sites from EDACS to P25 (unfortunately it most likely will still be all encrypted).
Here is the output for two tower sites picked up from PRO96COM
System ID : 197
System Name :
WACN : 9254A
Tower Number (Decimal): 401
Tower Number (Hex) : T0401
Tower Description : (null)
Control Capabilities : Voice,Registration
Call Sign(s) :
Timestamp : Fri Sep 16 21:49:44 2011
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth,Slots
00,769.21875,0.01250,30.00000,"Confirmed",0.00625,1
-Frequencies
#Format: Channel,Usage,Frequency(/Slot),Input Frequency(/Slot),Hit Count
"00-0040","c",769.71875,799.71875,0
System ID : 197
System Name :
WACN : 9254A
Tower Number (Decimal): 7501
Tower Number (Hex) : T4B01
Call Sign(s) :
Timestamp : Fri Sep 16 21:52:34 2011
-Tables
00,770.20625,0.01250,30.00000,"Confirmed",0.00625,1
-Frequencies
"00-0020","c",770.45625,800.45625,0
james32746
Lake Mary, FL
I am now pretty sure this is the new SLERS aircraft overlay system because every talkgroup that has come up has been encrypted and the old EDACS aircraft sites have been turned off at least in Orlando.
I think eventually this system will also replace EDACS system over time.
ki4wbn
Decatur, GA
All of the SLERS aircraft sites statewide have been 'upgraded' to P25 as of a month ago.
And yes, over time P25 will take over EDACS....but over time is the key there.............
