New State 700Mhz licenses
#1
I found several new 700Mhz licenses issued to the state, presumably for the new P25 TRS.
They are:
WQYB659, Hudson St Hartford
WQYC312, Storrs/Tolland/Union/Somers
WQV1750, Plymouth/Bristol/Wolcott/Middlebury/Bethany
WQYD924, New Haven County
WQYB928, Bridgeport area
WQYB620, Middlesex County
WQYA819, Rocky Hill/east lyme/new haven
WQTR788, Haddam/westbrook area
WQTR986, New Haven county
WQVI750, Litchfield/Hartford/Newhaven county
WQVI751, East Haddam
WQYA371, New London
pro106import
Milford, Ct. perched high above Long Island Sound
#2
They are:
WQYA371, New London
And some new updated licenses for the 800mhz. system that they presently use show Phase II emission status.
ff2sherman
Plainville, CT
#5
That one is in the list was the location accidentally duplicated with different names, I show about 18-20 SY Radio Services listed for State of CT.
I Will toss all frequencies in the scanner as I drive around and see what Control Channels I grab
Call Sign/Lease ID Name FRN Radio Service Status Expiration Date
1 WQNA368 CONNECTICUT, STATE OF 0003568011 SY Expired 01/18/2012
2 WQNA369 CONNECTICUT, STATE OF 0003568011 SY Expired 01/18/2012
3 WQOL635 CONNECTICUT, STATE OF 0003568011 SY Active 11/08/2021
4 WQOL636 CONNECTICUT, STATE OF 0003568011 SY Active 11/08/2021
5 WQTR788 CONNECTICUT, STATE OF 0003568011 SY Active 03/31/2024
6 WQTR986 CONNECTICUT, STATE OF 0003568011 SY Active 04/01/2024
7 WQTR987 CONNECTICUT, STATE OF 0003568011 SY Active 04/01/2024
8 WQTV652 CONNECTICUT, STATE OF 0003568011 SY Active 04/22/2024
9 WQVI750 CONNECTICUT, STATE OF 0003568011 SY Active 02/25/2025
10 WQVI751 CONNECTICUT, STATE OF 0003568011 SY Active 02/25/2025
11 WQYA371 CONNECTICUT, STATE OF 0003568011 SY Active 07/28/2026
12 WQYA819 CONNECTICUT, STATE OF 0003568011 SY Active 08/02/2026
13 WQYB620 CONNECTICUT, STATE OF 0003568011 SY Active 08/09/2026
14 WQYB659 CONNECTICUT, STATE OF 0003568011 SY Active 08/09/2026
15 WQYB928 CONNECTICUT, STATE OF 0003568011 SY Active 08/11/2026
16 WQYC312 CONNECTICUT, STATE OF 0003568011 SY Active 08/15/2026
17 WQYD924 CONNECTICUT, STATE OF 0003568011 SY Active 08/29/2026
18 WQYG914 CONNECTICUT, STATE OF 0003568011 SY Active 09/26/2026
19 WQYQ844 CONNECTICUT, STATE OF 0003568011 SY Active 12/14/2026
20 WQYR574 CONNECTICUT, STATE OF 0003568011 SY Active 12/21/2026
We shall see what I am able to grab from these, Thanks
Taxachusetts
#9
that would be a first step, see if they are actually in use.
If/When a Control Channel is found, then log the SysID, RFSS, NAC etc and make a submission for that Frequency/Site
so i am putting the frequencies in my scanner as we speak and i have to put all the frequencies that are FB2
cg
Connecticut
#10
They are not new but are 18 months old. Sites are coming online for testing every couple months. Keep in mind that the 800 will not be completely dismantled, some frequencies will be converted to P25 and with the 700 become a single P25 Phase 2 statewide system.
Your best bet is to simply set up a search for the 769-775 range (6.25KHz) and use Control Channel only.
Also, it may take a while before you regularly hear activity as the new installations are tested. If there are no radios affiliated with a particular TGID on the 700, that talkgroup will not be active on it.
chris
ff2sherman
Plainville, CT
#11
the Hartford site have activity on it all day,
Mostly CT Trans but it is there
I already preloaded all the CSP Talkgroups the only thing that is on often with the Hartford is Troop H
