New SYSID?? 01BA-0101 ??
troymail
Silent Key
maus92
The OP
If you take the LatLon coordinates from the fcc database, the site is at C Pier, near where the control tower is located (and the BWI Admin offices.) I haven't looked in that area for a new tower....
CA
Annapolis
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
But the tower may not be there at all; it's not so uncommon to have a landline link of one kind or another so the tower can be remotely located. It's possible that's where the control point is located, perhaps?
73s Mike
TinEar
Glen Burnie, Maryland
Excellent catch Troy. I programmed the control channel (very strong here) right after you posted your message but I haven't seen any activity on the system yet. Have you?
Alan
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
<sigh> Looks like another system that will need to be rebanded. 5 will get you 10 the freqs were approved without the managers even knowing that it will happen, whenever....73s Mike
troymail
Silent Key
Alan
Just control so far... maybe they'll do some testing this week....
troymail
Silent Key
I don't expect they'll need very high power but this control channel is almost undetectable inside Fort Meade.... possibly just low power during initial testing, etc. or could be just lower power given the area it needs to serve....
n3bxv
Severn, MD
Running Pro96Com against this system shows Callsign of WQBR528 which is that Expired license we discussed last year.
It's also only showing Freqs
866.2625
866.725 (shown as Alt Control Channel)
867.8625
WACN is default Motorola BEE00
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
n3bxv
Severn, MD
866.2625
867.8625
867.275 now showing up in pro96com as a Voice Channel as well.....
TG16 (T:101 DT) was also logged as active around 2009 local....
n3bxv
Severn, MD
Pro96com confirmed all the License Freqs today -
866.2625
866.725
867.275
867.325
867.8625
It logged 9 Radios and 9 Talkgroups active today, Did anyone hear any testing?
n3bxv
Severn, MD
There may have been more activity, however I forgot to hook up the Pro-96 to the AC Adapter so the Batteries died sometime during the day...
troymail
Silent Key
Well I finally took the time to try getting this new system up using UniTrunker... unfortunately, the signal strength has dropped way, way off since I first encountered it. I even moved my setup out of the basement to see if that would help but no go.
My trunker connected radio (BC-245) sounds very fuzzy ans weak but my BC-396 sitting right next to it locks into the CC without a problem.....
Does anyone else have the capability to try UniTrunker against this system? Can you get it to decode?
TinEar
Troy, I checked the control channel tonight and am seeing the same signal strength that I have since the beginning - it's between 5 and 6 bars. I still haven't caught any voice on the system but I haven't really spent that much time listening to it. I just check it occasionally and spend a few minutes parked on it.
n3bxv
Severn, MD
I'm running UniTrunker against it now as well - Its showing near 100% Decode rate, and it's showing Channel numbers but not the associated frequencies... Hmmmm.
Nevermind- I got the frequencies to display by entering into the [F]ind Menu..... and poof they appeared..
BTW- for anyone who may run into problems with the microphone input, make sure that "Microphone boost" is NOT selected under "Advanced Properties" for the Windows Mixer Control for the mike...
