u new to digital!
Dave
I just got the psr-600 i do have a uniden 996 so i have some exp in the digital trunked scanners however i dont think the gre scanners are that hard to use with a good explanation.
So it is a virtual scanner in a sense ,I really suggest buying the arc500 software
from
www.butel.nl its like $40 ,,with your subscription to Radioreference.com
you can use that software to download complete systems from radioref and then upload to the scanner
So what happens is you load up the 500 or 600 like it has 20 banks but they are called "scanlist " with either talkgroup ids for trunked systems or conventional freqs
each tsys will support 1800 objects IE>frequencies/talkgroup ids and so on
when its full thats it for that one now the scanner has 20 virtual storage files for each radio system you create so you created a setup you store it as a backup and name it then
you can create a new one and so on then if you want to go back to the say first one you created you reload it in 3 buttons and less then 20 seconds
thats the best i can describe it i hope that kinda helped /Matt.
Ps...where you from ?
