new to forum and scanners have many questions
lectricanman
hello everyone i am new at this so bear with me. my question is i just bought a radio shack pro97 it says it has no rebanding support could someone explain what that means also my local police has no freq number only talkgroup is this scanner compatible? i bought this mainly for rec purposes and to listen to local fire and ems any helpful info is greatly apreciated and look forward to using the forum thanks
KC4YIN
Kinston NC
First we have to know where you are and what system you want to monitor before we can be of help.
lectricanman
I am in southwest fl
northport to be exact I would like to listen to local fire,ems and police along with whatever else i can pick up its been 13 yrs since i had a scanner
fineshot1
NJ USA (Republic of NJ)
Your gonna have to do better than that description. I can not locate any "Northport, FL" on the map. PLEASE TELL US WHERE YOU ARE. What county are you in? What town in that county are you in? If your town is too small it may not be on the map. What other larger towns are near you? The USA is a big place....
fineshot1
OK - Sorry - I found it. So North Port is two words. Thats why my search did not find it cause you posted it as " northport " in one word. Yes - Highpockets post is probably correct.
gmclam
Fair Oaks, CA
Read about rebanding here: http://wiki.radioreference.com/index.php/Rebanding
Read about your PRO-97 here: http://wiki.radioreference.com/index.php/Pro-97
I use the PRO-97 to receive talkgroups in my area. But all radio systems are not the same.
You should have been reading here and learning BEFORE you bought the scanner.
Good luck.
Hammond, IN
I know this is a wee bit off-topic but...when it came to trunking, I know I definitely should have done my "homework" here first. I was lost for about a week :eek:
