graywoulf
Well I did not even get much use out of my Technician ticket and I already passed my General so I am going into HF as well. I just bought my first HF rig which is a Kenwood TS-570DG so I am going to need an antenna. The problem is that my house is situated near a lot of power lines and the only tall trees are on one side of the property. I am looking at a end fed dipole that covers pretty much all of the bands and is 98 feet long. The maker of this dipole says that it is compact enough to use in most any configuration. I quote... "The antenna can be installed as a sloper, an inverted "V", an "L", or even bent 90 degrees to fit a longer wire into a smaller lot."
It is priced at around $70. A friend has suggested a vertical multi band HF antenna, the "Maldol HVU8" as an alternative but they are over $300 and I see reports that they do not do well on 80 meters which is the most active band or so I have been told. So, I thought I would throw out a line here and see what comes back to me on this from you seasoned HF hams. I hope I have given enough information but if not, just ask. Thanks in advance for any help on this.
