New to Satcom Monitoring
CSL126
Tuscaloosa, Alabama
Hey guys, I've been listening to vhf/uhf and hf for a few years, but I was thinking about getting into satcomms. Can someone please point me in the right direction. I realize that most stuff on satcomm is encrypted. What type of antenna works best? Also, what is the best reciever out there for monitoring uhf satcomm, I have a PRO-2052 and a PRO-96. I have a 40ft mast outside my house that I could mount an antenna on, I suppose at UHF i'm going to need some high-quality coaxial cable as well. Any information would be appreciated. Thanks in advance!
jlh
csl126, there have been several posts re satcom recently. search in the military monitoring forum here for related posts. a lot of good info.
Dorset, South UK
CSL126: Hi, UHF is easiest to get started with. See if you can find a 220MHz antenna from the ham-band. This will be a good start. You can of course build a helical antenna if you want to have the proper polarisation etc. For some ideas, have a look at the gallery at http://www.uhf-satcom.com/rx/
Coax can be double-screened sat-tv coax, it will be fine providing the run isnt 100's of feet. A low noise amplifier certainly helps, you can often find wideband TV mast-head amplifiers cheaply, and these will do the job.
We have an IRC channel for satellite enthusiasts, details at http://www.uhf-satcom.com/irc/
cheers,
Paul
(contributor to uhf-satcom.com)
