Minnesota is not mobile scanner friendly. You must have a ham radio license or written permission from the state to legally put a scanner in your vehicle.
With that said, a 996 is not recommended for a statewide system because it has limits on the number of things that can be programmed into one system.
The 536 would be a good scanner, unless you travel into metro areas that use simulcast systems. It can have its moments on decoding simulcast systems, as I've seen from trips to MInnesota. The SDS 200 is the best choice in those area.
the 996 also isn't great with simulcast
For some reason I just don't 'see' the SDS200 in a vehicle. Too bulky and wide, sunlight makes screen fonts unreadable if you don't have a 'night screen - black font/white bkgnd - and intricate menu navigation that would make it difficult to make adjustments while on the go. And, if you have your scan menu QKs all assembled down to Channel level I think changing up your lists would prove very difficult. At least it was for me when I had it in the RV. Just MHO, I think the SDS200 is the perfect home base station scanner. Vehicle? The BCD536HP would be a more ergonomic choice, I believe.
JD
kf4anc
From a vehicle I would agree. However there are exceptions where the 996P2 can work every bit as good as a SDS100/200, my home is one of them.
ajconkle, Most every state in USA requires you to either A, hold a valid ham radio license, or B, be a member of a volunteer fie/ems to have a scanner in a vehicle. I remember seeing a map stating of such on this site.Minnesota is not mobile scanner friendly. You must have a ham radio license or written permission from the state to legally put a scanner in your vehicle.
Actually only about 5 States have laws restricting the use of scanners in a vehicle.ajconkle, Most every state in USA requires you to either A, hold a valid ham radio license, or B, be a member of a volunteer fie/ems to have a scanner in a vehicle. I remember seeing a map stating of such on this site.
I beg to differ with you, New Jersey is VERY tough on this!Actually only about 5 States have laws restricting the use of scanners in a vehicle.
See:
Are Police Scanners Legal?
Are police scanners legal? Yes, police scanners are legal in the U.S. View details including regional restrictions while driving, committing other crimes + more.www.zipscanners.com
