JimmyL1011
I've been an Amateur Radio Operator, scanner owner, SWL since I was little and always had all of my stuff crammed into one apartment or other. 3 years ago I bought a house and have been working, little by little, to rebuild my radio station almost from scratch. The below pictures are of my new antenna and tower installation which will bring my station to full operational status.
My original setup was 38 feet of Rohn 25G tower next to the apartment building I lived in with the antenna cables, mostly RG-58U, fed through a bedroom window. I added a taller pedestal section and another 10' section of 25G so the tower is 50' high and to the tippy top of my 2M vertical, I go as high as 65' above ground.
Weathering was a major problem with my previous location so I decided that if this was going to be a state of the art installation, I would forego the lossy RG-58U and step up to Andrew Heliax 1/2" hard line. Getting it into the house meant cutting a hole in the rear of the brick wall and feeding the cables through a weatherproof boot. Using silicone weather sealant was necessary to prevent rain or moisture from seeping in. This stuff is a pain to work with but once it's hooked up and ready to go, it's well worth the hassle.
My tower consists of a Hy-Gain G7-144 2M vertical, an ICOM broadband discone, a Hustler discone and a Dressler amplified 25-2000 MHz antenna. The tower itself is grounded with 2 8-foot ground rods pounded into the ground and individual ground kits connected directly to each of the Heliax cables. I have a complete weather station atop the tower as well as a large red strobe light just below the top of the tower for special occasions.
I will post pics of my station soon. Stay tuned.
