OK - My first page came through. It decoded, recorded and converted to mp3 and emailed properly. Also only received 1 email. But, after that the program froze. I just re-started it, will see what happens.
I installed it on my Win7 machine and it works just fine. Now I need to try it some time on my firehall machine (which is either XP or 98, I forget which) and see if I can get it to behave there.
EDIT: Is there a place to change "This is an email sent with python"? That's gonna confuse my recipients.
asmith136 said:I have this running and I found that the email audio sounds tiny or has an echo. this is on the same computer that I had the Two Tone V24 running with no audio problems.
asmith136 said:When do you think the Tone offset feature available?
This would be hard to get right, since if a dispatcher pauses partway through a dispatch it could terminate the recording, which wouldn't be desirable.asmith136 said:Do you think you can add a feature that would stop the recording after a set time that there is no audio and send the email and use the record time as a Max timer. This way if the message is short the email will go faster and if its long message it will continue to record.
Update on my testing. I have v.40 running on two separate computers, Computer #1 seems to be working OK with no freeze-ups. There was a problem this morning with an error.(See attached text file, error is at the bottom of page) I believe this may have been a multiple tone situation, but not sure. I am monitoring a large dispatch center, but only using a few of the tones.
Computer #2 crashed overnight and now TwoTone will not load. This is mostlikely a problem with my computer as I have had issues with it in the past. I will download the program again and see if it will start.
This is a fantastic program, keep up the great work.
If I make changes to your TwoToneDetect40.py file how do I convert it to a .exe/application?
johnmac said:Any way to hold those error messages so we can read them?
johnmac said:Is there any way to auto delete the wav file after the mp3 file is created, so there are not duplicates and also save disk space?
Traceback (most recent call last):
File "<string>", line 61, in <module>
File "E:\Python\build\pyi.win32\TwoToneDetect4\outPYZ1.pyz/ConfigParser", line
322, in get
ConfigParser.NoSectionError: No section: 'Section1'
I'm getting the following error:
Code:Traceback (most recent call last): File "<string>", line 61, in <module> File "E:\Python\build\pyi.win32\TwoToneDetect4\outPYZ1.pyz/ConfigParser", line 322, in get ConfigParser.NoSectionError: No section: 'Section1'
I do have a config.cfg with [Section1] as the first line (and am using the config.cfg file from the latest TwoToneDetect40.zip). Any thoughts?
Thanks!
File "<string>", line 90, in <module>
File "E:\Python\build\pyi.win32\TwoToneDetect41\outPYZ1.pyz/ConfigParser", lin
e 351, in getint
e 348, in _get
ValueError: invalid literal for int() with base 10: '.4'
Getting an error
