Highpockets
Using V-Scanner
That's the point we're up to Frank, that's when he gets the errors, when he hits the commit button. The screens you showed, that's where he is at!
Using V-Scanner
No, that's not accurate.So, as I explained above, you cannot simply load V-Folders into V-Memory from the computer. Every upload goes to V00 (working or active memory) in the scanner. You must then store it into V-Memory from the scanner's keypad before uploading the next file to active memory, which will overwrite the previously uploaded data.
I got same error with one of my three hookups. Clicking Refresh resolve the issue.Please look at my attachment so you can see what I am seeing
Close/reopen V-Scan dialog produced the same results...two cables and scanners ok while third gave same error requiring clicking Refresh a second time to complete operation.
I have tried probably 50 times and each time same error message. Now one question I use Win Vista 64 bit. Could that be an issue
Mr. Don Starr,
Since the latest Windows Mobile devices are coming to the market at around $350 carrier subsidized, they probably don't have as large an audience as they once did. The growing trend, other than the Apple iPhone, is Google's new Android OS. With the recent releases of multiple Android mobile devices like the Hero, Droid, and Nexus One which are being called real competitors to the Apple iPhone and possibly the final death of Windows Mobile, have you considered a Win500 Remote Client application for the Google Android OS?
With the cost of Windows Mobile devices skyrocketing, the Android platform is quickly becoming the next generation for mobile devices including slates, tablets, and media players like the Archos 5.
The Android developer SDK is available at Android Developers.
AND maybe as an incentive for you, Google has done two developer challenge contests providing thousands of dollars to the winning developers.
Don,
I added a Virtual Scanner Management section to the Utah Guide, following my own directions, I get no errors, I hit refresh, it goes into Remote V-Scanner Mode, I hit Commit and it transfers ok, I hit done, it reboots and I'm back to normal scanner operation. But, when I go into V-Folders using the buttons on the scanner to see what's in the Folders, nothing transfered. What am I doing wrong, so I can correct the Guide?
I think I found my problem, I was hitting refresh after I filled in the files to be sent, it worked when I hit refresh first (Remote V-Scanner Mode) then filled in the files.I think the guide is right now.
