Highpockets
I was going to ask about that (hitting Refresh between selecting files to write and hitting Commit).
I just tried the sequence in the Utah guide, and it seemed to work just fine.
Thanks!
Nice Steve, worked perfect here also.
I just downloaded Win500 evaluation software but cannot communicate with my Radio Shack Pro-106 scanner. I purchased and installed the Radio Shack programming cable and it appears as com 5. The Win500 software seems to be set to com 9 but I don't see where to change this setting in Win500. Also is there a manual available for Win500? Thanks for your help.
WIN500 - UtahRadioAlso is there a manual available for Win500?
Win500 doesn't need the COM port setting because it finds and "talks to" the cable's drivers directly.
However, this does require that you have the current drivers for the cable. I don't think RadioShack has the current drivers on the CD, but you can get them from here: Virtual COM Port Drivers . You want the first driver listed (version 2.06.00). I recommend using the "setup executable" link to the right, under "Comments".
Also, make sure you don't use the short "adapter" cable that came with the RadioShack 20-047 USB cable.
I just released new versions of Win500, Win96, and Win97:
- Re-wrote SOAP interface to RR. This should improve import times. This version no longer requires my RRLib.DLL file or Microsoft's .NET runtime.
- Fixed double download of trunked systems
- Added progress indication to trunked system download from RR
- Added zone number to site info in RR download and sorted site list by zone/site
Since the update, Win97 has been giving me an error when I try to save file using "Save" or "Save As". A message box will then appear saying "Error: Access violation at 0x004659B0 (tried to read from 0x0000654A), program terminated." This error occurred on both my Windows XP desktop and Windows 7 laptop. I also run Win96 and Win500 from these same machines and those programs run and save fine.
Works ok now.I just posted version 1.32 which should fix this.
The only reason I installed .NET is to run Win500. Has anyone actually removed .NET and then used Win500 with satisfactory results? If so, I plan to remove it.I just released new versions of Win500, Win96, and Win97:
I was only considering it to free up resources and try to speed up XP's performance but I guess I'll leave it alone. Thanks for your input.I wouldn't remove any of the dot net versions. Other programs may depend on them.
Also you may have several versions of dot net installed. Keep them all because of the following:
1) Dot net versions are designed to co-exist with other dot net versions.
2) Later versions do not replace earlier versions.
3) Programs that requires dot net needs a specific version.
