New Wouxun GMRS radios
vagrant
ker-muhj-uhn
California
I like the 21 model for the small size and lack of things for people to fiddle with. Basically get on a set frequency, lock it and enjoy. Still, the power limit remains acceptable for all of the frequencies. The battery looks like it would last a bit and charge via USB is nice. $50 price point?
AK9R
Staff member
Super Moderator
Central Indiana
The test report makes me laugh. The certification lab tested one model. But, the report applies to 32 different models. Yeah, right.
tweiss3
Is it time for Coffee?
Ohio
And the power output reported to 3 decimal places for simplex frequencies, then just a flat 4 watts for the repeater inputs.
nd5y
Wichita Falls, TX
Read the DoS Letter.
TWO-WAY RADIOS KG-989, KG-978, KG-916, KG-866, KG-839,
KG-939, KG-998, KG-988, KG-828, KG-968, KG-958, KG-928, KG-969, KG-918,
KG-959, KG-T56, KG-T58, KG-T59, KG-T52, KG-T53, KG-T55, KG-T57, KG-T60,
KG-T61, KG-T62, KG-T63, KG-T65, KG-T66, KG-T67, KG-T68, KG-T69, KG-989G,
KG-879G FCC ID: WVTWOUXUN21.
These models are identical with the PCB design, components and electromagnetics compatibility characteristics.
It's not unusual to have many different models that are electrically identical with the same FCC ID.
AK9R
Staff member
Super Moderator
Central Indiana
That statement doesn't address the possibility of firmware differences among those models. You and I both know that changing a few bits in the firmware can change a radio from compliant with the rules to non-compliant with regard to out of band transmit, front panel programming, etc.
I know that the scope of these certification labs is limited, so they are some aspects of FCC rule compliance that they don't check. It just raises an eyebrow when I see so many models lumped into one FCC certification test. What you are saying is that Wouxon has 33 different radio models using the same design that are all compliant with Part 15 and Part 95E. I'm skeptical.
