Hi!
I need help!
I live in enough of a VHF/UHF deadspot / the repeater tax news that I only just learned about from a few years ago have convinced me to start using HF. I've had my eye on the Icom-IC705 basically since it came out, so I figured I'd take the plunge soon.
I want to be able to operate from my house, so that means installing an HF antenna for the first time. I understand the need to ground it, so I'm getting 10AWG grounding wires and I plan to attach one of these: Moonraker UK Limited 11-252 Moonraker Ltd GPA-80F Fiberglass HF Vertical 80-6M Antenna | DX Engineering ("Moonraker Ltd GPA-80F Fiberglass HF Vertical 80-6M Antenna") to a pole on my roof, add one of these: ICOM AH-705 Icom AH-705 Compact Antenna Tuners | DX Engineering ("Icom AH-705 Compact Antenna Tuners") to the base of it and then into one of these: PolyPhaser IS-50UX-C0 PolyPhaser Coaxial Lightning Protectors | DX Engineering ("PolyPhaser IS-50UX-C0 - PolyPhaser Coaxial Lightning Protectors"), with the grounding connection going via a clamp into 10AWG grounding wire to then be clamped to the roofjack that my mains electricity goes through - which I hope is grounded, I mean my god.
My question is: is this likely to be effective for HF, and is this sufficient lightning protection in the event of a direct strike?
Ben
km6zeb
I need help!
Ben
km6zeb
