I'm a computer scanning newbie plinking on my RadioShack dual trunking Pro-95 scanner (No snickering at my dinosaur, please... ;-) And I stumbled across this great website and the forums and signed up.
I know this is the install forum, but it looks like the closest thing to what I'm interested in.
Just started playing around with my scanner again after several years and found some software via this website to allow me to push frequencies from and to my scanner from this website called Win95.
Has anyone found a straight forward way to convert the .xml files from this website feed to something that can be imported into Win95 software (Win95 V00.13 made by Dan Starr http://www.starrsoft.com/Win95) or does someone already have a hot Win95 Scanner Database file (.p95) for the RadioShack Pro-95 for the Atlanta, GA area?
If not, maybe someone has a better way to get the frequencies and trunk info from this website into the Pro-95?
I searched, but didn't find anything. If this should be moderated to a better area, please push it over there.
I'm interested in Gwinnett / Fulton / DeKalb Counties sort of frequencies.
Thanks in advance.
I know someone figured out how to program their Pro95 already.
Remember how you did it if you've moved on to bigger and better things???
I'm sure your scanner is probably better.
I'm working with what I have here, just getting back into my scanner.
Any points in the right direction would be appreciated.
Thanks!
Thanks in advance.
Thanks!
