Newbie with a dumb question
#1
Greetings:
I want to download a feed which is broken up into segments in the archive. I want to save the segments for about a day and a half. I downloaded the first segment and had no problem. When I went to download the second segment I was told that it had the same file name. I must be overlooking something obvious. Would someone direct me to comprehensive information about downloading .mp3 archive files? Do I have to do each segment separately? Can I download a range of the segments? Can I download a complete day's feed?
I thank you in advance for your assistance.
Michael
teufler
ST PETERS, MISSOURI
#2
you got the first days file, rename so it does not conflict with the second day. just aid a 1 or 2, or 3, etc to the file names and then you should be good to go.
