ltng92
Is it possible to hear Nextel walkie-talkie conversations with a scanner? What about the Nextel "off-network" walkie-talkie conversations?
Nextel uses iDEN. The modulation is 16QAM. The voice data is VSELP. You'd need a receiver that could do both. I don't think there's a consumer grade scanner that will do this.ltng92 said:Is it possible to hear Nextel walkie-talkie conversations with a scanner? What about the Nextel "off-network" walkie-talkie conversations?
No, they are in the same un-blocked portion of 800 mhz as other trunked 2-way systems.Matt_45 said:All of the transmissions will be in the blocked chunk of 800mhz bandwidth so most scanners (especially newer ones) won't get you anywhere.
Direct Talk is an all-digital off-network walkie-talkie service that works between compatible phones within a range of up to 6 miles. Terrain, weather, foliage and man-made structures (such as buildings), among other things, may impact range availability. Direct Talk operates on the 900 MHz ISM public frequency and provides group and private walkie-talkie capability. This valuable service is ideal for use in remote locations, as a back up for emergency situations, or when network coverage may not be available.
phil_smith said:I also belive it is only available on the i315, the i325, and the i325 IS.
Bill2k said:Every phone Nextel sells has the Direct Talk feature. If its not mentioned in the key features list, click "view all" next to key features and Direct Talk will be listed there.
EDIT: Before someone bites my head off for not being specific. Every phone nextel sells now. I have no idea about the phones they sold last week or prior.
Thayne said:Nextel is presently moving a lot to 900 freqs they acquired here in Colo.
Also direct connect and the "Walkie talkie" feature are 2 different things. Direct connect is on all nextels and is IDEN and uses the network , Walkie talkie is not IDEN, as mentioned by others.
