n4voxgill said:
communications are provided by Motorola under a contract between the NFL and motorola. The teams have no say so. The contract requires coach and assistants to wear the modified headset that has motorola in big letters for the camera to pick up. The bookies would actually kill to be able to listen on on these communications. Notice how often the coach covers his face with his play sheet. Other teams and the bookies have hired lipreaders to try and read the lips. This is no mickey mouse operations, millions of dollars are at steak.
Actually the system for the coaches is made by Telex. I'm not sure why the big M's on the headsets (Some type of contract is probably the right guess). If you look behind the benches you will see a pole with an array of two dishes pointed to the side boxes. They clearly have Telex on them. Telex is also on the cart with the equipment behind the benches and on the equipment on the belts. This is a special system made only for the NFL.
The QB radios may very well be Motorola though. I have noticed backup QB's on the sideline with a portable radio listening in. This system is controlled by the NFL. They do turn it off when rules state and turn it back on at the end of the play. Thats why a repeater type system is used. They can disable the repeater and stop comms. If it was simplex they couldn't do this.
Comms have to be secure to keep the other team from listening in. I've heard, and believe it to be true, that if one team has trouble with comms and it can't be corrected, the other team will not be permitted to use their radios until the other system is up. There is plenty to search for at a game. Close call will find some, but some of it is very low power.
Merry Christmas, and happy searching,
Frank K3FSS
