Any negative effects with using a GP with a NGP antenna?
Receiving only, ThanksWhat band are you asking about? Are you transmitting or just receiving?
was wondering if the ground plane would have any negative reception issues.
Receiving only at the 150 MHz bandWhat band are you asking about? Are you transmitting or just receiving?
If that's true then the antenna was not designed as a genuine NGP but as a normal GP and removing the ground plane make it loose 2.15dB as the direction beam goes up in the sky.No, it won't. In fact, like I said above, it'll change the radiation pattern and give you about 2.15dB gain compared to using it without the ground plane.
