Niagara On The Lake FD
Gator596
Niagara Region - Canada
I'm wondering if the freqs in the DB for this service are correct... All I ever hear on them is Elora and Guelph FD calls. The DB lists NOTL FD as 153.770 (dispatch) and 150.755 (PL110.9).
Are these working for anyone who listens to them regularly or are you using different freqs?
motomeso
Ontario
Wirelessly posted (Mozilla/5.0 (BlackBerry; U; BlackBerry 9810; en) AppleWebKit/534.11+ (KHTML, like Gecko) Version/7.0.0.254 Mobile Safari/534.11+)
I believe the 153.770mhz has been long abandonded in Niagara and just the 150.755mhz is in use. I think there's another frequency in the 148mhz range too if I'm not mistaken.
mciupa
DB Administrator
Moderator
Looking at TAFL shows that it is not licensed for NOTL.
I will remove it.
Thanks for pointing this out.
Gator596
Looks like they have dropped the pl on 150.755, which might account for me not hearing things originally...
Heard a couple of calls today that came in with 5 bars and no pl was detected.
8.5kms from the tower and 12kms from the mobiles.
BCD996xt, d-130J at 35ft, LMR400
mciupa
DB Administrator
Moderator
Noted and changed.
Thanks for the notification. :)
torontokris
Toronto Canada
Thats one reason I like to run in SEARCH mode for PL tones, you may pick up MORE then you needed but sometimes its worth it.
Or run 2 idential frequencys , 1 with the known PL/DPL and another in SEARCH mode to get everything on that frequency.
