Niagara Region Railroad 2-Way Radio
firefgtr
Welland, Ontario Canada
Would anyone who lives in the Niagara Region listen to railroad Frequencies? I have the option on my scanner (BC769D) to scan the RR radio Frequencies but nothing turns up.
exkalibur
York, Ontario
In Niagara, you'll find CN on Channel 1, End to End - 161.415, and Channel 3, Dispatch - 160.935. For CP Rail, you'll find them on Channel 82, Hamilton Sub Standby - 160.815. For Trillium Railway, you'll find them on (I believe) 160.445.
Saint
Fort Erie Ontario Canada
Frequencies
I can tell you living in Fort Erie Ontario, all the Railroad frequencies are very busy, including Buffalo NY, check your scanner setup .
Steve
thomas724
Mississauga, Ontario
Railway Frequencies in Niagara
Trillium Railway (Port Colbourne Harbour Railway) 161.400 161.415
CN Grimbsy Sub & Stamford Sub 161.415 160.935 Talking Hotboxes as well
CP Hamiltom & Montrose Subs 160.815 160.845 160.335 161.325 Yard 161.355
Hope this helps
Thomas
firefgtr
Hope this helps
Thomas
whats a "talking hotbox"?
homerjay
Beamsville, Onatrio
A talking hot box is a trackside monitoring device that uses thermal devices to measure each axle temperature for a worn out bearing. Worn out bearings cause axles to seize and possibly de-rail the train or a portion of it.
I've only once herd a hot axle.
