Nicecast with Mojave?
One13Truck
N.E. Pa.
#1
I've been using Nicecast for my feed since I moved it to, well, RadioReference at the time. I'm still running High Sierra as my OS so Nicecast still works with it. I'd like to update to Mojave but looking at the info in Nicecast I'm afraid it will finally do in my use of it if ai update.
Anyone else using Mojave? What are you using to broadcast your feeds with on it?
richtidd
Live Audio Administrator
San Mateo, Ca
#2
Note: Nicecast from Rogue Amoeba has been retired.They recommend migrating to Audio Hijack for a modern broadcasting setup.
Their is also BUTT you can use.
Please see here:
https://broadcastify.zendesk.com/hc...Alternative-Broadcasting-Software-and-Clients
