SDS100: Nip it In the Bud
UPMan
Uniden Representative
Arlington, TX
#1
Ok, one disappointment on the final units with final battery. I really don't like battery life (max 320 minutes). So, we'll change to a high-capacity battery (entails a new battery door and making the unit about 8mm thicker at the base...which should actually relieve those of you worried about instability).
But, we aren't going to delay first shipments. Instead, all first adopters with the "standard" battery will get a free extended battery+battery door once they are available, around August. All you'll have to do is register the scanner and we'll automatically send when ready.
Here's the notice we're putting in the box for those first units:
IMPORTANT NOTICE!
After final design, we found that the battery life with the included battery did not meet our expectations for run time. So, we are changing our design to use a bigger battery that can last 8 hours. When this battery is ready, we will send you one, at no charge. Simply register your scanner at:
my.uniden.com
We appreciate your patience while we get these into production.
ShyFlyer
Colorado
#12
August seems like a long time away...until one looks at the calendar and realized that it's nearly June!
Thanks for the update UPMan! Not only is it great news that the SDS will have at least 8hrs of battery life, initial scanner units should also be shipping soon and Uniden isn't going to shortchange early adopters just to get rolling on production!
Fremont NE
#15
so will the later revised units have a thicker case? Or will the later revised units look identical to the first units once they (the first units) receive the parts in the mail in august?
jasonhouk
Marion, Ohio
#16
To my understanding:
The case will not be thicker, the battery cover will be deeper and not flush with the rest of the back case to accommodate the higher capacity cell.
Houk
ScanFanEd
Southern California
#17
Wow, excellent handling Paul and Uniden. At this late stage, I am certain some or many companies would have not taken any action and just looked the other way. This says a lot about you. Nice job and thank you!
milf
Careful, I CAN hear you!
Indianapolis, IN
#19
SDS100 SHIPPING SOON.... If I had the cash... I would go Gollum on it at full speed! Same will be me when Whistler TRX 100 hits....
