nj state police
#1
hello i have a pro-93 scanner i was reading an article from back a few years about rebanding and it stated that as long as the fourth # after the decimal point was not a 0 it would be able to trunk, my question im trying to scan the nj state police troop a and im seeing the cc as 860.9375 859.9375 858.9375 857.9375 so the fourth # after the decimal point is a 5 i should be able to scan the system is this correct, also if it cannot is there a way that i can put in the id's and possible set something up to where i can scan the system showing the id's so i can see them, thans for any help
wtp
Port Charlotte FL
#2
yep
it should trunk.
the radio is only analog so if anyone changed to digital you will just get noise.
i would not worry about the talkgroups yet. set it up and listen for a while.
and yes about the 5 in the forth place.
