NJICS Municipal Migration Discussion - Statewide
GTR8000
Well Known Member
BEE00
Or just simply Oakland PD with the Te mode, since "Ch 2" can't be monitored anyway...KISS! ;)
Eatontown has begun it's migration over. DPW has already made the move. I don't know when the other departments (PD, FD, EMS, OEM) are planning on making the switch.
Northern NJ
So far guys, on Oakland....
The lowband multicast has been on and off over the past few days.
Listening currently(16:00hrs) only 700 is active.
I am locked on both lowband and 700.
Not sure if there’s problems or what.
And on 700 there has been no “E” so it should be coming through on lowband unless there’s a problem
Update: 16:22 now I’m hearing E and no lowband.
Perhaps there was a change.
I’ll keep listening through the night and I’ll advise
Ok one more update. Based on the ids, 242059(E), and the others, this is dispatch console and the units running tests.
242058 is the dispatch console(clear).
At this point my assumption is testing.
Deep in the heart of Jersey
I've heard them on lowband alot today, can't get over to NJICS fast enough to see if it's multicasting.
Sent from my Pixel 2 XL using Tapatalk
Northern NJ
May have been earlier in the day.
I got home about 15:45-1600.
Listening to both locked on, lowband was quiet, when 700 was open and E
Back on Thursday I caught TG 4917 active with a short encrypted keyup.
The RID was 242041 which is an Oakland ID.
I don't want to submit to the DB yet because one keyup is not very much to go on...
Northern NJ
And to be clear this is not their Ch2 the E right? From what I’ve seen, they can/do run E on the same TG as dispatch.
So a possible Tac channel?
I heard a unit ask another unit to switch to channel 2 a few weeks back, which resulted in the traffic on TG 4915 becoming all encrypted between the same exact two RIDs which were previously being used in the clear.
Yup, there are several potential uses, but tac is one of them.
Coffee runs probably lol
