NJSP 800 MHz Custom Trunking Tables for PRO-96
#2
Having the same issue with NJSP frequencys. How did you Figure It Out.
Currently am using a Uniden HP 2
Need Troop C
W2SJW
Senior Member
Moderator
Northwest NJ
#3
Need Troop C
There is nothing needed for a 800/900 Type-II system on any of the newer Uniden scanners, including the HP's.
#4
So no custom band plan is needed just use standard band plan option? Trying to use the Wildwood Repeater/Tower in Cape May County.
I'm kinda brand new to this stuff.
