NJSP Trunked
citylinefilms
#1
Hey All good evening, I was wondering Using the Arc15 for my BCT15 and programming NJSP Trunked via Radio Reference Do I need to upload all 16 sites ?
High Bridge, NJ
#4
Phillipsburg is an odd case here. You may have a hard time getting the system depending on where you are. Reception is difficult in the low area's.
I would start with North Simulcast. If that doesn't work, try the Montana Mountain IR site. You won't get much off the IR site other than the local NJSP Patrols.
citylinefilms
#5
Thank You So much I appreciate it, I was curious is there anyway to Scan Faster with this Bearcat Bct15. My Vertext Vx-900 Scans all FDNY,EMS, and NYPD and Pics Up the Transmissions seeming like in a instant soon as Dispatch or a unit transmits
