NMO antenna rubber gasket question
aleckrohto
Hi everyone, have a quick question about an NMO mount and antenna, I installed on my vehicle. I recently bought a Larsen tri band, however I accidentally threw out the rubber gaskets that goes on with the antenna (RGNMOANT is what it is similar to). It rained a few days ago pretty good and I am worried that my NMO installation was compromised. Just curious, will I be fine without one and is my installation compromised. Thanks.
Mile High, or more.
The NMO mount gasket would keep water out of your vehicle. the o-ring of gasket at the antenna base needs to be in place to keep water out of the area between the antenna and mount.
If the NMO mount was installed correctly, using the o-ring that is included with the kit, then there will be no damage to the installation.
If you installed the antenna without the gasket at the base, it is possible some moisture got in there. But not a big deal. Take the antenna off and clean/dry everything well. Use the link above to order a new gasket and install it.
Even with the gasket installed, it's always a good idea to periodically remove the antenna and check the underside and top of mount for any moisture. I usually do it every time I wash the truck.
