Nmo Trunk Lip Antenna Mount
repairman222
Missouri
Does anyone know a website that I can by a Nmo trunk lip mount with coax and a male bnc connector already on the coax end? I have found alot of them but only have a PL259 connector on the end off the coax and I want a Male Bnc. Wanting one just like in the Picture, Thank you.....
repairman222
Missouri
Where would be the best place for a Nmo trunk lip antenna mount to be mounted on the lip of the trunk? Middle , right side or left side of the lip of the trunk? I have heard the left side of the trunk is where a lot of people mount cb antennas to try to stay away from power lines to help with reception. Would this be also true for scanner antennas? Thank you Members.......
jwt873
Woodlands, Manitoba
If you can't find a trunk lip with a BNC, just use an adapter.. The fraction of a dB loss won't make much difference.
I have a little Hyundai Accent sedan. (You don't see many sedans of any make on the road lately :) ) I installed the NMO trunk mount in the middle of the trunk and I use an adapter.
The only downside to using an adapter is that you will put more stress on a handheld BNC antenna mount. My radio is held fixed, so cable flexing etc isn't really an issue.
