NMO150/450/800SF
trentbob
W3BUX- Bucks County, PA
So it absolutely has to be 806-960? If 750-870 will do you...
Arcadian sold me one unit last year.
trentbob
Yeah, I need to go up in 900 MHz. I can give Arcadian a call and see what they say, but the website lists minimum of 6.
Yep I looked it up and it said minimum of six and also it said out of stock.
jeepsandradios
East of the Mississippi
Not sure if your looking for the new or old style but amazon has the old unit for delivery Friday. Shows shipped from Wiscomm so maybe ping them ? My last one came from Antennafarm and only took a week.
trentbob
If I remember correctly the old one which has been around a long long time was a scanner monitor antenna only and was not rated for transmit. Also doesn't have the spring or heavy duty mount.
It is an excellent scanner antenna, but not for commercial use. I could be wrong, they may have upgraded it for TX in latter years.
alcahuete
Antelope Acres, California
Thanks guys. I'm definitely looking for the new SF model with the spring and better mount. Tessco has them in stock, I believe, but the $96 or whatever seems fairly steep.
Yeah, if you don't have an account with Tessco, they'll hose you on the price. With an account, it's around $53.00
The Antenna Farm doesn't show them, but you could give them a call and see if they can get it for you. When I've ordered from them in the past, it always came in packaging with labels that resembled Tessco, so I suspect Antenna Farm uses Tessco as their source for some of the products.
jeepsandradios
It was used for years in public safety on transmitters. Was a solid unit. Not sure where you read it was for RX only.
As reference I logged into Tessco also and show the -
NMO Tri-Band 150-174/430-520/806-960 MHz
  • TESSCO SKU: 282887
  • QTY: 1 EACH
  • UPC: 888063472626
  • MFG PART #: NMO150/450/800SF
On sale for $35.00
Tally only shows the the standard for $45
alcahuete
Yeah, I don't have nearly a big enough account with them to get those prices. I will definitely try Antennafarm. I didn't see it on their website, but I will give them a call and see.
They definitely use Tessco. I actually had a few antennas drop shipped directly from Tessco, in the past. Still had their packaging and labels and everything. Never went to Antennafarm first.
When Larsen first released the NMO-150/450/800, it was marketed as a monitor antenna. There was no mention of transmitting, power handling capability, SWR, etc.
After a few years on the market, they changed. It started being marketed as a multiband antenna for multiband radios, probably around the time the first tri-band LMR radios hit the market. It does just fine when used where it's designed. I think it's good up to 100 watts.
trentbob
Yep, thanks, I remember now where I saw it was for RX only... It was on the antenna itself LOL. It was right on the ring of the top of the nmo mount. We are talking when the antenna first came out, must be 20 years or more. I see now it is rated for up to 100 Watts.
alcahuete
alcahuete
Holy crap! Just checked TESSCO for something else, and the NMO150/450/800SF just went on sale for $35! I attempted to order 3, and it says I am not an authorized buyer...even though I have placed dozens of orders with them. Argh!!! Have to wait and call them tomorrow morning.
And the older model NMO-150/450/800 is $32.04
Not sure if they still have the $50 minimum order, though. Might have to order one for myself.
