No audio, but Line in is working?
Signal3and2
Iowa
I got a message saying there is no audio on my feed. Sure enough, there isn't. I haven't changed anything, and this computer rarely gets used. Just sits and runs ScannerCast all day.
The Line-In that I have always used is still working, if I turn up the volume in my volume settings I can hear the scanner audio over my computer speakers like it should. Somehow it's not coming across on the feed though. Any suggestions?
gmclam
Fair Oaks, CA
Record Properties
The path from the sound input to ScannerCast is not the same path as from the sound input to your speakers on the local computer. You use the "playback properties" to hear locally. Use the "record properties" to control the sound source and level to ScannerCast.
I use a digital level meter to constantly monitor the levels I am streaming. There is a thread on here about it. The meter I use is by DarkWood.
To get to the record properties, right click on the speaker icon, open volume control, select options - properties, then select recording.
