No Digital on Pro 18
Hello,
I have a brand new Pro 18 Digital iScan. I can hear analog transmissions but can't hear Digital(P25). I can see the digital channel on the scanner but can't hear anything.
Is there some setting that I'm missing?
kd7ckq
No. AZ
It's most likely a Encrytped Transmission. Does it show [E] at the top during the transmission?
Hi,
I don't think it's encrypted. The digital here is mostly unencrypted and the scanner doesn't get any digital at all.
kd7ckq
No. AZ
Where is here? What system? Also, under ADVANCED FEATURES. Set the first tab under Encryted Digital Audio Settings to AUDIO TONE.
Now when ever you get a Encrypted Transmission, you will hear a busy dial tone.
I'm in Nova Scotia Canada. The system is the Aliant Trunked Mobile Repeater system and is Motorola Type 2. I have the audio tone turned on. I have older scanners that can pick up digital fine.
I should mention that the firmware and DSP has to be updated for this scanner; its out of date. But I don't know if that impacts the digital issue.
I'm using the PSR 800 application to program the scanner so I guess that's as issue too. Is there a workaround for this? I'm in Canada so the Pro 18 app doesn't support Canada.
