no luck
#1
hello trying to reach salem county with a stock 800mhz antenna and the psr-500 from newark cannot hear anything tried the analog channels from database and the trunked 800 frequencys from data base cannot hear anything from salem county. . i thought i would be able to reach, but i guess not. does anyone from newark have a stock ant that can reach salem county?
S.E. PA
#2
Salem County NJ uses a 500MHz trunked analog system, check the DB again.....And don't forget to set the correct offset and base freq.
#3
I can hear Salem just fine when passing through Newark, may be that your using the 800 antenna instead of either a general coverage or uhf antenna.
Ryan
