no outgoing talk?
poorman
Hi guys new here, ive had a lot of CB's over the years and have had a few troubles but managed to overcome them LOL ... anyway i dug out an old ground plane antenna i had in the garage rafters and put it on a tripod on the porch roof (tin) and tempoary used a barrel conector to hook 2 new cables togeather from the antenna to the radio, and it picks up great but if i try to transmit it just keys up and thats all i hear when im outside on another radio... it just clicks and no sound, but if i talk from my truck back to it its loud and clear as a bell, i tried 3 different radios and i get the same thing :( any help would be great
PS: all the items im using have worked before (except the new coax) thanks
Dawn
Pinecrest,Fl
You're going to have to be more specific. Are you saying that you are receiving a dead carrier on your mobile with no modulation?
poorman
ok let me try to explain better, (im not good with the technical terms at all)
i have a old ground plane antenna with 1 upright and 3 downward fingers
i mounted it on my porch roof thats a tin roof
i cant talk out on it all anybody hears is me keying up up to about 3 miles away
i can hear them talking up to about 3 miles away (had a friend in his truck driving around for me)
first i tried a very old base station and couldnt get out
second i grabbed a noble unit and a battery pack and it dont get out (just keys up like the otters)
and then i tried one more noble radio and it just keyed up too,
all 3 have there own mic's and i even switched them around once,
ive never had this kind of trouble before, thanks for the help
PS: im on moderated status so it may take a while for my replies to show, thanks
poorman
here is what i got in pictures (i hope)
all the parts were cleaned and shined up before putting it up
first picture is the top side of the mounting bracket
second picture is the top side after i loosened it
the third picture is the bottom side after i slid it down after loosening the top nut
last picture is what it looks like up
GSPD
Is there an insulator of some type on the radiating element to insulate it from the mounting bracket?
DisasterGuy
Maryland Shore
The situation that you describe really doesn't make much sense. You are getting power out (having someone at a distance hear your carrier) but do not have any modulation. Modulation should not be in anyway tied to the antenna or feedline in this case.
poorman
no isolators at all. its metal to metal, i thought that was odd BUT i heard it working at a friends house years ago, after that i got it from him and put it in the garage rafters.
i dont under stand why it will key up to somebody down the road but they cant hear any talk :(
thanks guys, i wish i was more "smarter" about what im talking about im sure it would help :(
poorman
ok little update.... last night i lowered the mast and clamped an old K40 trunk mount antenna on the bracket where the GP was and raised it back up and i can talk OUT! only about a 1/2 or so but its not been tuned and its old. so now i need to figure out whats wrong with the GP as to why it wont talk out...
poorman
got the ground plane working "sort of" BUT the SWR is all the way to 5!!! :( cant seem to get it down any ideas? thanks
