Hello to all,
I am not new to communication receivers, I have a (ok) idea of the inner and outer workings of my radio(s) and I have had my 396XT for a few years not having any problems with it.
Now for no reason it will not receive ANY signals (other then and occasional high pitched sound in the 900 range)
I have done all I can think of, The ATT is off, I have tuned to my local Los Angles area weather 162.550 (Nothing), I have used my Icom f4-gs to TX (4watts) on the exact freq. and using close call and nothing!
I have replaced the antenna, checked the SMA connection and I even carefully took it apart to see if the center from the SMA to the board is cracked (It is not) And I tested for continuity from the circuit board (PH-309EA) to the antenna, And the continuity is good..
I don't know where else to turn but to ask here to all the really smart people here on RR
So what do you guys think?
Did I kill my 2nd favorite reciever????
TIA to all
Dr. BLAH
IC-R20, BCD396XT, PRO-2005/2006, WS1010, Sony ICF-IC1, And a few older ones
”Those Who Sacrifice Freedom For Security Deserve Neither.” -Benjamin Franklin
TIA to all
Dr. BLAH
