I didnt even know about the RF gain, that fixed it. Thanks
Depending on the design, not just adjacent-channel, but strong signals many megahertz away can overload it into hearing things that aren't there and not hearing things that are.Dongles are more susceptible to adjacent channel interference that could wipe out your reception. So you have to try turning down the gain.
Thanks for the reply. I indeed tried that with no success.Dongles are more susceptible to adjacent channel interference that could wipe out your reception. So you have to try turning down the gain.
Thanks... basically selling them with light weight antennas for indoor is a joke. Having to hook up am outdoor rig to a $30 dongle is another joke. But you are right that is an answer as I hooked up my 40 foot high uhf/vhf and it made the dongle "functional".As was posted by AM909 adjust the RF gain by increasing it. The other important thing is the antenna. An outdoor antenna generally works better than an indoor one and a larger antenna generally works better. Antenna height's important too. I use a discone 20 feet above ground and pic up 5 out of 7 NOAA wx stations in the vicinity. My dongle is the one sold by rtl-sdr.com, one of the best in my experience.
From my listening post in the basement, I just tried my PSR310 with factory antenna and was not able to pick up any NOAA WX stations. Connecting the telescoping tripod that came with the RTL-SDR kit, (still in the basement extended about 18 inches) I was able to pick up the local WX station (11 miles away).Those little included antennas with the dongles may work just about as bad on a scanner as the dongle.
