Noise in radio
billdean
Michigan
I still have that Firefly antenna installed as my Larsen is still crossing the county on it way to me. One thing I have noticed in using my Bill 3 is the noise when on coming traffic passes me. Not every vehicle does it but quit a few do. I am thinking this is still the function of a bad antenna. If not I would like to fix it before my new one arrives.
Might be RF interference. Used to be that the old ignition systems were really noisy and caused a lot of interference to radios. Radio Shack used to have a page pretty much dedicated to mobile interference reduction.
Now, it can be cheap USB chargers, they are notoriously bad RF noise generators.
Cheap LED lights are another.
If it's only occasional, it's probably not your setup.
billdean
Michigan
I have tried a few things but didn't notice much difference. I did go from a known ground under the hood to the antenna mount with just automotive wire while I am waiting for some ground straps to come in. I think that might have helped a little. My set up is working and getting out but not as it should, I don't think. I am 6 miles from the e-way and don't hardly hear anything. Part of it may be the swr but I have a cheap o meter to check it with that I don't have much faith in. My NANO_VNA came in today but now I am waiting for the adapter.
slowmover
Fort Worth
Antenna system picks up most of the noise.
— Adjust NRC on RX to help. (#3 or so)
— Adjust RF Gain to when “quiet” first starts on other than 19. (Quarter turn or less)
— Use SQ to modify.
Have to get used to local environment plus local operators (not Skip) get the above “right”.
Need DRX-901 speaker.
Remove coax from radio, turn it up (don’t TX) and listen for vehicle noise sources driving around.
See K0BG
billdean
Michigan
— Use SQ to modify.
I do use the NRC on RX and TX. The default position on them is #3. I have mine set on #5. More is better, is it not?
slowmover
Fort Worth
Yes and No.
Past changes vehicle to vehicle, and past differences metro to metro (or state to state), while 5 is “quiet” it also sorta distorts voice.
DRX-901 speaker is that which I strongly recommend. How a man says something is as important as what he says.
— Under stress, many don’t find words and try to adapt incorrect choices via modifications.
It isn’t that 5 is wrong, it’s that 3 serves well (right external speaker) to get best of enunciation, pronunciation, cadence, etc, against background noise.
Experiment as you go along.
