Noise
apd3190
Maryland
Im getting alot of distortion in my radio. When i touch the antenna it quiets down. What am i doing wrong and how do i correct it?
k9rzz
Milwaukee, WI
Gonna need some more details my friend!
What radio?
What antenna?
What frequencies? When listening to what?
Is it "noise" or "distortion" and distortion in what way?
This radio?
images
I suspect it's a 'grounding' issue, but we really need more details on your setup and problem.
apd3190
Maryland
Yes thats the radio. Just have a longwire on the roof of the house connected to the radio antenna. Its a hissing stactic type of noise.
k9rzz
Milwaukee, WI
Okay, now where getting somewhere.
I don't know what 'hissing static' is. I thought it was distortion?
Is this when you're listening to a station? or in between stations?
What frequencies? All frequencies?
Is this problem new? Is the antenna new? Have you made any changes lately?
I'm still thinking ground or bad antenna connection.
Ken_Allen
The antenna shouldn't be on the roof. It should be above ground, not touching your house at all. There should be coax feedline running outside and then into the house, to the radio.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
A point here - some portables require a hi-z (hi impedance) input to have an antenna work well. A coax input may not be the best choice in these cases.
I agree it could be a ground or antenna issue, but I believe this fellow is in an apartment, so getting a good RF ground is not really a practical matter. I doubt the landlord would allow him to run a wire down to a copper pipe....73 Mike
[edit]
A couple of additional thoughts (brrr...sitting in a 18 degree car will really shock your brain awake...)
I would be quite cautious about making a RF ground for a portable like this. Chances are you may expose yourself to a shock hazard, particularly if the ground for the DC isn't well isolated (and in a cheap portable, I kinda doubt it is). If there's no jack for a ground, I'd pass this by. Besides, a good ground for a plastic-cased radio is not likely to help all that much.
One of the most common problems with portables is the wall wart. These can be noisy as heck - withness the comments by hertzian about the Sat750 and the well known problem with the E1. Choking the wall wart off can be done with a kit from MFJ (or if the Shack still carries it...). The easy way to test for this is to run the portable on batteries - if the noise goes down, you know what needs doing.
There are SO many possible sources of noise on HF - whole books have been written on the subject. Some common ones are these CFL bulbs (nice for the environment, some of these are real noise generators - I have one in my condo and can't say a darn thing - wipes out anything below 6 mhz or so that isn't real strong...), wireless routers and modems, many kitchen appliances...the list seems endless. Time for some detective work. Take your portable, collapse the whip and listen on a frequency with nothing on it. Reduce the RF gain, if you can, just so the radio starts to hear its own noise level. Walk around and see what gives you the most headaches.
Loops are a better bet when you're in an apartment or condo - they can reject some kinds of noise, and some have a detachable element so you can move it around and find that sweet spot where things are reasonably quiet. Degen, Kaito and a few others sell 'em, and many are not all that expensive (there are some - like the Wellbrook and AOR models- that are VERY expensive - no point putting something like that on a 390, frankly). There are even some designs you can make yourself with some tools, and knowing how to solder.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Interestingly the support doc below says that the antenna jack is grounded- so it is possible to do without a potential shock hazard. Still, getting a good RF ground in an apartment is a tall order...
DX-390 200-0214 Connecting an External Antenna
Connecting to a cold water pipe is iffy at best. There's no guarantee that the joints are all nice and clean, and the distance the water pipe goes around just to get to the source is so large, it might act as its own antenna. Still, I suppose it's something...
73 Mike
nanZor
Great points!
One thing that might help is that you don't always need to connect to say a water-pipe or other truly grounded source. As you mentioned, this serves as a safety-ground, but if the connection to earth is too long, it acts more like an antenna radial.
Hence, the simple radial that merely lays on the floor or ground can make a big difference. Just a simple 8-10 foot piece of wire attached to the radio's "ground" and thrown on the floor without attaching to anything is usually a great improvement. It isn't a safety-ground, but RF surely likes it. :)
FOR SAFETY reasons, the radio with a radial wire is operated from batteries ONLY, and not connected to the AC mains. If you are running from a wall-wart or any other connection to the AC mains, do not use this radial-wire technique unless you are fully aware of the electrical shock hazard that can be created by having a floating ground wire just laying around.
apd3190
Maryland
This is what i did. Bought a kit from radio shack (Basically a long piece of wire) ran it across my roof outside. Ran the feed line down and wrapped it around the radio antenna. I also have a radio shack amplified antenna which im not using at the moment. I thought putting the wire on the roof was better than nothing. Im getting more into this after sometime away and looking for ideas. Since i dont really know what im doing i dont know what im missing. I guess im missing alot both shortwave and scanner.
woody_46
Canada, Eh!
Noise issues can be a pain to track down. I found a new one yesterday when white noise wiped out the 40M band. The kids had brought their laptop downstairs. The noise level was an S9.
Before that I had constant AC type noise for about a month that was driving me nuts. It finally stopped when the streetlights went out on the whole street. Once fixed, the noise was gone for good.
lanbergld
Richmond VA
If you will loop that longwire back around, and connect the 'free end' to the grounding shell on the antenna jack, your noise will go away. Just have enough loop out there to receive well. I've been Dx'ing like this for years. Works great. I only do loops because of that.
Just experiment making large ugly loops. The larger and uglier, the better. One end runs into the center pin of jack, the other end to ground shell. Start with a spliced piece of coax.
Larry Lanberg
Richmond VA
