Saturday I got back out and started working again.
I stopped down at the local radio shop and they bent my L bracket so it would fit. Great because after looking at part numbers for fenders I determined the pro.fit probably wouldnt fit from the Colorado.
I tested it up and down the hood checking SWR and found it made zero difference so I put it where it didn't obstruct my view.
I used #10 self tapping screws and only had the first one go in crooked. I just used the screw to fill the hole luckilly it was the first one and I just moved it over.
I didn't use any lock washers so I'm watching closely. I also didn't use any sealant. I may add a little rtv down the road.
I've studied many forums and some folks think grounding straps are necessary. The antenna doesn't require grounding and all of the connections are metal to metal so I skipped it at this time.
I used a crimp on style uhf connector on the feed line.
Any way the pictures of the antenna:
I had some worries about this. The bracket was still short so the little plastic cover over the solder point might scab the paint. Time will will tell.
I got my speakers mounted. One for each side of the Kenwood TM-V71A. These surplus emergency speakers do pretty good. The only thing I ran into trouble with is that different folks have louder audio output so the quiet guys make me turn up the volume and the louder folks make the sound a bit distorted. I dont think I can fix this for the price I paid for these.
After much review this is the place I chose for the mic. I had tried double sided tape but the factory supplied mic hanger just didn't have the surface to hold it. Sorry about the fuzzyness.
Finally I need to update my magnets for this Chinese made LED light bar but it runs off the circuit just fine. The video isn't great but its all I had.
https://www.youtube.com/watch?v=xme4Yxs69Wc&feature=youtube_gdata_player
All I have to do is pull the seat, flip the heat sync up on the radio, police the wires, and reattach the mic coupler. I won't post pictures about that.
Thanks for all of your help, a thanks to Pointon Communications, and thanks to everyone in the YTARC yahoo email group (Yellow Thunder Amateur Radio Club.)
I hope my pictures and this writeup can help. I spent hours searching and there were only two or three Trailblazer installs found on the web.
That antenna blows my mind on recieve. Its about 4" lower than the MFJ-1422 on a Mag mount on the roof. Scares me driving in wooded areas. I did have my arm hanging out the window while testing at 50 watts. Don't do that.... OUCH!
73.
Sent from my SCH-R970 using Tapatalk
